Originally Posted by
mactec54
Lc1975
I thought you were using a laptop with an express card, I have tried 3 different cards and none would supported Mach3, having a desktop is a different storey, no problem with this having/using a parallel port
To test the cable run a program and check with a meter and see if you are getting the 0-5v out,on the X Y axes pins, then do the same for the breakout board, it may be the wiring between the drives and the breakout board, what part did you disconnect, that is most likely where your problem is, it may also be a drive problem, I have a board like this, which makes it easy to test computer output, cables Etc
