586,089 active members*
3,966 visitors online*
Results 1 to 11 of 11
    Jul 2006
    141
    Table top for 48x96 table
    I previously built a Precision plasma table and have had it make money for the last 5 years.
    We have the materials and another gantry coming for a new table but this one for a router. The work area will be 48x96 with room for oversize table top.
    My question is what do you use for a table top? With plasma, you have a water pan that holds your slats and your material sits on top of the slats.
    With a router, I need a table top, then be able to put a good spoil board on to that.I was wondering what you all use when you built your tables?
    Any help is appreciated!
    Thanks in advance,
    Grindergary
    May 2005
    3920
    Re: Table top for 48x96 table
    Since you are already running a plasma machine the first question that comes to mind is this; will you be machining any sorts of metal on the machine. If you primary interest is wood then MDF is passable. If you expect to do metal then a metal table is in order. The reason being any serious metal cutting will require a lube/coolant, this is a bad combo with wood products.
    Note that on machines this size you need a frame under the table or part of the table. You don't want to leave this supporting framework as an after thought.
    Jul 2006
    141
    No this table is strictly wood products. I understand what you mean by needing a frame under the table for support of the sheets. I just am trying to figure out what way to do it. Can't seem to find any pictures of a system that is being used. I will keep looking at build threads and maybe get an idea.
    Thanks for your response!
    Gary
    Jun 2012
    817
    Large torsion box?
    Jun 2004
    6618
    I take it that humidity may not be too bad in your area. You could use MDF.
    I would probably prefer plywood as the sub base. Then you can cut up some 3/4" MDF and use 1/2" T-tracks in between. Pick your own spacing and frequency. That way you can level out that section of MDF many times and use it for a spoil board. You can replace parts of it that gets damaged and relevel. With T-track, you can use T-nuts or toe clamps. Unlimited varieties actually.
    The torsion box is a fine suggestion too. It doesn't have to be very thick to make it solid.
    Lee
    Oct 2008
    1147
    I've always built my cnc machines as table top machines from 18x18 inch machines to 6x10.5 foot machine. When you go over a 4 foot wide machine it can get a little tricky because sheet goods you use for your base only goes up to 4 foot wide. At that point using multiple aluminum extrusions between your X rails and having a 4 foot wide table underneath makes since. On top of the cross beams between your X axis, I like to use two sheets of MDF that have been glued together then 1 sheet on top that I screw down as a spoil board. One thing I would highly recommend is not building a base under your large cnc machine that won't let you add a vacuum hold down system later on.
    35538
    Plywood is a little better choice than MDF for the table base layer, as it's a little more stable than MDF. A lot of people use a layer of plywood, then a layer of MDF, followed by another layer of MDF for the spoilboard.
    Jul 2006
    141
    Quote Originally Posted by Devastator View Post
    Large torsion box?
    Don't mean to sound dumb, but what is a torsion box?
    Gary
    Jul 2006
    141
    Seeing as I have not started to build the base of the frame yet, I understand what you mean. We, my partner and I, are discussing how high the top should be so we can machine certain sizes of material. If I build a base with extrusion, say 1 1/2" high and then 3/4" then 1 1/2" for 2 sheets plus another for the spoil board.I need to lower the support for the sheet supports to get our working hight. That is why we are trying to figure out what to use. Thank you for your response, informative.
    Gary
    Quote Originally Posted by FandZ View Post
    Jun 2012
    817
    Quote Originally Posted by grinder_gary View Post
    Gary
    https://www.google.com/search?q=tors...FZCViAodyuoGwg
    Jul 2006
    141
    Thanks, Now i remember that from years ago reading on this forum.
    Wife calls it oldtimers, lol
    Gary
  1. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  2. Replies: 0
    Last Post: 04-08-2013, 03:16 AM
  3. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 06:35 PM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
