586,655 active members*
4,470 visitors online*
IndustryArena Forum > CAM Software > OneCNC > How to mill the side of a part efficiently
    Oct 2015
    12
    Hello,
    I have XR6 express and I have a question. I am new to CNC milling (I've been messing with XR6 for about 3 days total) but have been programming lasers for almost 12 years and a waterjet for almost 6.
    I am trying to mill the side of a 2" steel block. I am attaching an image of what I'm trying to accomplish.
    The question I have is, When I do this using the mill profile command it is milling the profile then stepping down (z direction) a value I define and repeating the process. I have a 3" end mill and would like to do this in steps going towards the part (y direction) the full value of 2" depth. What am I doing wrong?
    927
    Re: How to mill the side of a part efficiently
    You need to set the "remove amount" and the "stepover" in the profile dialog to do what you are asking.. Then set the depth to full cut .
    If need be, you can post your sample file here. And we can have a look. And send it back with the values filled in for you to look over.
  1. Trying to figure out how to do back side of part.
    By DREXENG2015 in forum BobCad-Cam
    Last Post: 12-25-2013, 12:59 AM
  2. Bobcad V25, finishing side of part
    By phantom1500 in forum BobCad-Cam
    Last Post: 01-15-2013, 02:33 AM
  3. one way to zig zag. Part comes out smaller on one side?
    By Zeppelin1007 in forum WoodWorking Topics
    Last Post: 12-19-2012, 10:21 AM
  4. How to (easily) fixture the second side of this part
    By vandal968 in forum MetalWork Discussion
    Last Post: 12-17-2011, 03:09 PM
