I am in the process to install a mist coolant system on the mill. I have all components to be able to switch the coolant on and of from the computer. That is a relay and a 24v solenoid valve. I can think of 3 different ways to do this.
1 Use a available pin and control mist coolant with Gcode. I belive M7 is Mist on in mach. But what pin should I use and what signal can I get from it? 5 or 12V?
2 Use the same signal as from the flood coolant. By installing 2 mechanical switches in front I could chose if I want mist, flod or both on at the same time.
3 Just control it manually. But then it would be on untill I go there and shut it down.
I can't find any documentation on the novakon BOB but I hope someone here can lead me in the right direction.
