586,108 active members*
3,139 visitors online*
Page 3 of 7 12345
Results 41 to 60 of 129
  1. #41
    Nov 2015
    67
    Re: CNC egg shell carving
  2. #42
    Nov 2015
    67
    Tried the stained glass technique.
    Not succeeded yet as cannot see the stained glass effect.
    Attachment 332962
    Attachment 332964
    Attachment 332966
    Attachment 332968
  3. #43
    15362
    Quote Originally Posted by uvvvvw View Post
    Attachment 332962
    Attachment 332964
    Attachment 332966
    Attachment 332968
    Still brilliant work, how is the new machine coming along
    Mactec54
  4. #44
    Nov 2015
    67
    I almost forgot the new machine
    Playing around with some other machines in last few months.
    One of them.
    Auto Guiding Sky Tracker
  5. #45
    Dec 2007
    2134
    Just amazing work! Incredible stuff!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  6. #46
    Nov 2015
    67
    Just made a test on the reliability of the machine.
    25,000 0.25mm holes are drilled on a goose egg shell.
    No drill breakage :banana:
    But the hole position started to deteriorate after the first 1000 holes of a new drill bit.
    The flute length of the 0.25mm drill bit is 4mm.
    And from the photo, it can be found that the hole shift is up to 0.2mm approximately.
    Attachment 333896
  7. #47
    Jun 2010
    4256
    OK, the holes shifted - but why?
    I seriously doubt that the drill tip wandered that much: the drill would have snapped. (0.2 mm wander on a 0.25 mm bit?) Although it might have wandered a bit, as some of the hole spacings are very erratic.
    Perhaps the drill bit was getting a bit blunt? To be sure, egg shell is not hard stuff, but it could still be abrasive.
    Did the A axis start to lose pulses or something?
    Did the mathematics have round-off errors?
    Did the surface sensing have some hiccups?
    Did the egg surface make the drill bit skate around? (Possible, possible, especially if the drill bit was getting blunt.)
    Could you repeat the exercise but once the holes start to seriously wander, change the drill bit for a new one?
    Fascinating stuff.
    Cheers
    Roger
  8. #48
    Nov 2015
    67
    Quote Originally Posted by RCaffin View Post
    Fascinating stuff.
    Cheers
    Roger
    [Studied the enlarged photo again, I guess the wandering may be a bit less than 0.2. But should be up to 0.15.]
    [Look like tungsten carbide still gets some degree of flexibility.]
    [Two new drill bits have been used. calcium carbonate is sure a kind of abrasive material ]
    [I guess not, as each hole circle can be closed.]
    [Excel worksheet is used, without round-off.]
    [Surface sensing affects the hole depth only.]
    Did the egg surface make the drill bit skate around? (Possible, possible, especially if the drill bit was getting blunt.)o
    [Blunting should be the cause. You can see the true position of the holes are good when the hole count is below 1000.]
    [And it started to deteriorate significantly. I used two drill bits for this drilling. One for about 12,500 holes.]
    [You can find two shadow areas. They are where the 1000 holes areas for the two drill bits.]
    [In these shadow areas, the true position of the holes are good.]
    [On the other hand, the sound is very different. When the drill is new, the sound of the cutting is sharp and clear.]
    [But very soon, it became very dull. Just not like cutting, but punching]
    [I tested a 18,000 hole pattern before by using 0.3mm drill bit. Same result.]
    [I'm not surprised by this result. I have worked before in a PCB shop. We change new drill bit for each 1500 holes for 0.25mm drill.]
    [Of course, much difficult material - glass fiber reinforced epoxy]
  9. #49
    Jun 2010
    4256
    Hi uvvvvw
    OK, blunting and skating it must be.
    You know, I am not sure that FRE is more difficult than eggshell. Thing is, I suspect you can get inclusions in the eggshell - stuff like tiny bits of quartz (sand), and silica is highly abrasive.
    Ah well, next stop would be a diamond-coated drill bit, and after that maybe a laser?
    Apropos of nothing, I believe that some grades of aluminium can also be seriously abrasive: tiny inclusions of aluminium oxide get thru. Nothing like trying to drill AlOx!
    Cheers
    Roger
  10. #50
    Nov 2015
    67
    Tried the stained glass technique again.
    Some improvement. Can see the stained glass effect now
    Still need more practice to improve the thickness distribution of the ink.
    Attachment 334508
  11. #51
    Nov 2015
    67
    The thickness distribution improved a bit
  12. #52
    Nov 2015
    67
    My first ostrich egg shell, for new machine testing
    Attachment 337562
    Attachment 337564
    Tried to carve the pumpkin for Halloween
    Attachment 337566
    Attachment 337568
    Attachment 337570
  13. #53
    Nov 2015
    67
    Light bulb
    Attachment 338030
Name:	light bulb b.jpg
  14. #54
    Jun 2010
    4256
    Are you for real??? Engraving on the surface of a light bulb???
    Blimey!
    Or is it more of a 'frosting'?
    Cheers
    Roger
    PS: how many did you break first?
  15. #55
    Nov 2015
    67
    Blimey!
    Cheers
    Roger
    Sure it is real
    I used a diamond coated engraving tool to do the engraving.
    And this is the first light bulb. No breakage
  16. #56
    Jun 2010
    4256
    OK, I grovel.
    Cheers
    Roger
    PS: Free-range hen eggs next?
  17. #57
    15362
    Light bulb
    Attachment 338030
    Great work, imagination is a powerful tool keep it up, is this with the new machine
    Mactec54
  18. #58
    Nov 2015
    67
    thx Mac. and yes, it is the new machine for the ostrich egg.
  19. #59
    Nov 2015
    67
    This time, a candescent lamp bulb.
    A bit pushing the limit
    Attachment 338248
  20. #60
    15362
    Attachment 338248
    The new machine looks much better
    Mactec54
Page 3 of 7 12345
  1. DIY Laser Shell
    By trotec in forum Australia, New Zealand Club House
    Last Post: 11-30-2013, 07:06 AM
  2. Shell Moulding
    By razajahanian in forum MetalWork Discussion
    Last Post: 11-09-2010, 11:55 AM
  3. Using a shell mill
    By mrk in forum MetalWork Discussion
    Last Post: 08-11-2007, 02:59 PM
  4. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
  5. Cutting Shell
    By handersen in forum Glass, Plastic and Stone
    Last Post: 07-09-2003, 01:04 PM
