586,058 active members*
3,495 visitors online*
    Apr 2012
    161
    Reset Feed & RPM overrides with gcode
    Is there a way to add some lines in the gcode that will reset the manual feed and RPM override on Path Pilot? I try to remember to check these before I start a cycle, but I have missed it a couple times. It would be nice if this could be done in gcode, then I could just modify my post processor to always include it at the start of a program.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Jul 2004
    81
    Re: Reset Feed & RPM overrides with gcode
    I'm not sure how to reset the settings, but you can use M49 to disable the overrides. See M48 and M49 - Override Control
    or http://linuxcnc.org/docs/html/gcode/...#mcode:m48-m49.
    Apr 2012
    161
    That's good to know, but I still want to be able to use the overrides. I wonder if disabling then enabling the overrides would reset it to 100%. Probably not, but I'll have to try it just to make sure.
  1. Predator overrides
    By robrea in forum BobCad-Cam
    Last Post: 05-27-2010, 05:04 PM
  2. Feed Hold vs. Reset Button
    By georgebarr in forum Mach Mill
    Last Post: 07-03-2009, 10:10 PM
  3. feed hold switch reset
    By davelbert in forum Torchmate
    Last Post: 05-11-2009, 09:08 AM
  4. Is there a way to feed an offset in manually in Gcode
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2008, 04:30 AM
  5. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
