586,096 active members*
3,745 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Profile Toolpath - Cut width other than bit diameter?
    Dec 2014
    10
    For some projects I have used CamBam. In the profile tool menu you can specify a Cut Width. E.g. if you have a 3mm bit and set Cut Width to 4mm the bit will go around the profile a second time and open up the cut to 4mm. This is very useful as it makes removing chips a lot easier. I have, unsuccessfully, been looking in V-Carve for the same feature. The only work around I have been able to come up with is to define a second profile and offset that 1mm.
    Anyone have a better/smarter idea?
    Thanks.
    Re: Profile Toolpath - Cut width other than bit diameter?
    Set your profile up so it needs to make 2 passes to get to the depth you want, but have the first pass make nearly a full depth pass.
    Then check the Last Pass box and set an allowance.
    This is assuming you want to cut the full depth in one pass. If you're making multiple passes, then the passes can be whatever you want, and the final pass will be the offset pass, like a cleanup pass.
    I've never seen any other software that had a Cut Width option like your talking about.
    Jun 2013
    1041
    Mastercam allows multiple side passes, depth passes, or both. Alphacam does as well. I've never used v-carve so can't say for it.
    Ben
    Jan 2015
    5
    You can create a profile in which cutting move one millimeter, once completed you double the profile you created and this, you only have to change the displacement, all other parameters are the same
    Jun 2014
    777
    Yep what jmplug said, offset the vector n make a second toolpath to run first. Or simpler set the tool diameter larger than actual dimension on first pass and then set at true diameter for final pass.
  1. Cleaning up inside corners on profile toolpath
    By jmalarke in forum PhotoVCarve and VCarve Pro
    Last Post: 03-14-2015, 04:37 PM
  2. Replies: 3
    Last Post: 06-13-2014, 10:59 AM
  3. Pocketing same width as tool diameter
    By David Kraft in forum Rhinocam
    Last Post: 11-02-2012, 04:58 PM
  4. Newbie help w/ Profile toolpath
    By EndIsForever in forum Rhinocam
    Last Post: 10-03-2009, 05:43 PM
