586,072 active members*
4,508 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > convert 5v PWM signal into analog signal ranges from -10 to +10 v
    Aug 2014
    4
    hi folks
    I'm trying to do some custom servo motion control, for that purpose I need a basic circuit that converts the output signal from the controller that is 5v PWM and Direction digital output to analog signal ranges from -10v to +10v
    Example:
    PWM signal 90% and Dir 1 >> 9V output
    PWM signal 75% and Dir 0 >> -7.5v output
    I'll be very happy to see your suggestions
    Feb 2007
    966
    Re: convert 5v PWM signal into analog signal ranges from -10 to +10 v
    with my step 2 linear,. you could control the analog amp with simple step/dir signals
    Servo Adapters, ViperServo
    for the PWM signal, an opamp with lowpass filter, differential opamp with reference set to v/2 would do the job.
    Larry
    Jun 2010
    4256
    You can buy such units off the shelf.
    Cheers
    Roger
  1. Controlling motor with +/-10V analog signal
    By Sandy H. in forum DIY CNC Router Table Machines
    Last Post: 12-01-2013, 12:38 AM
  2. analog +/-10V signal gen
    By visky in forum Want To Buy...Need help!
    Last Post: 05-01-2008, 03:40 AM
  3. PWM and DIR -> +/-10VDC analog signal
    By visky in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 09:28 PM
  4. analog signal from serial port
    By roni21702 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-09-2007, 05:06 PM
  5. Getting analog signal from pc
    By roni21702 in forum Computers / Desktops / Networking
    Last Post: 06-15-2006, 07:34 PM
