587,427 active members*
3,092 visitors online*
Hybrid View
    Oct 2005
    859
    fanuc 160i ncboot32 error
    I have a fast ethernet card supplied by the OEM and some files they told me to load from the NCBOOT32 in maintenance mode (switch set to 0). I can not load the files but get an error instead.
    Example file to load is 6567l.mem when I select load I get
    INTERNAL ERROR
    CNC couldn't execute the command
    Function: 106
    Status: 2
    Error: 3
    l1:0
    l2:0
    l3:0
    l4:1000
    O1:0
    O2:0
    O3:0
    O4:0
    Feb 2015
    161
    Re: fanuc 160i ncboot32 error
    Click on "About" and press the "S" key, you should see the pop up, System mode or something like that. That will enable software files to be edited. Though newer FANUC CPUs require a special card in order to load or remove software. A card only FANUC engineers have. Also, when software is saved, it is removed from the control, making the control useless until it is loaded back in.
  1. Fanuc 160i .Cannot boot
    By Jeff_B in forum Fanuc
    Last Post: 05-19-2013, 11:48 AM
  2. Please help! Adding axis to Fanuc 160i
    By ausman12 in forum Fanuc
    Last Post: 01-28-2012, 07:41 AM
  3. How to Upgrade to Win XP on Fanuc 160i
    By sigit in forum Fanuc
    Last Post: 01-22-2010, 09:31 AM
  4. Fanuc 160i-M Series Controller
    By kevin08 in forum Fanuc
    Last Post: 07-11-2008, 03:05 PM
  5. Replies: 2
    Last Post: 02-03-2008, 03:45 PM
