586,104 active members*
3,403 visitors online*
    Dec 2007
    17
    CAD/CAM general question
    Hello,
    I need help with generating a part to an STL file. I had a colleague of mine generate it but it was not curved, but instead angled.
    We are using DeskCNC (Carkin) to run our CNC XYZ router table, but that's a whole another issue. It will accept DXF or STL files,
    but since this is a 3D part, I was told that STL might be a bit better.
    This is generally what we want to machine:
    However, the part we are trying to machine is a block that is 4" x 4" x 1/2" thick with a cylindrical shape cut out of it so it appears similar to this:
    Attachment 298424
    Again, it is not 8" x 2", it is 4" x 4". The radius required is 5 17/32".
    So basically it's a block minus the cylindrical portion removed. I have tried several different CAD programs including FreeCAD, but could not get
    it to work. Call me a CAD dummy.
    I am attaching what I came up with for the STL file and resulting G-code (NC code).
    However, when I run this on our setup, the axes stall through DeskCNC. Maybe the
    rapid moves are stalling the motors? We have been able to cut simple parts with the
    same config, but then again this is a different type of G-Code file.
    Any hints or help are very appreciated.
    Mike
    Attached Files Attached Files
    Jun 2014
    777
    Re: CAD/CAM general question
    The rapid move could be set at any figure but will be overridden by your controller softwares motor tuning if the rapid in gcode is faster. So if the motors have stalled because of the feedrate then your controller motor tuning needs adjusting.. Rule of thumb is find the speed at which the motor stalls and set the max velocity at 70% of stall speed.
    As for cad cam you could use fusion 360 which is free to hobbyists or companies that even under 100k a year.
    Being as though the part is reasonably simple it looks to
    Me as you could just output one face of the end of the part to a dxf and extrude into cadcam in any format.
    Jun 2006
    3063
    Parts in STL format a re usually made of of thousands of triangular meshes, which don't them selves well to most CNC machine operations. If a generic file format is needed try IGES or STEP and then generate DXFs from that.
  1. General air question
    By Scrambled1 in forum HURCO
    Last Post: 05-03-2015, 05:19 AM
  2. a general CNC question
    By cazloco in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2008, 08:51 PM
  3. General question
    By kal_pesh in forum Mastercam
    Last Post: 06-20-2008, 01:57 AM
  4. general question
    By ajdcnc in forum Mach Mill
    Last Post: 11-02-2007, 04:30 PM
  5. general question
    By biker3 in forum Vertical Mill, Lathe Project Log
    Last Post: 05-10-2007, 11:47 PM
