586,070 active members*
3,543 visitors online*
View Poll Results: What softwares do you use? Pick all that apply.
Voters
105. You may not vote on this poll
  • Mach3
    84 80.00%
  • Corel Draw
    17 16.19%
  • Autocad or AutoCad LT
    25 23.81%
  • 123Design
    4 3.81%
  • Sketchup
    11 10.48%
  • Other please post comment
    33 31.43%
Multiple Choice Poll.
Page 1 of 3 123
Results 1 to 20 of 57
    Lightbulb CNC 6040 6040Z - China Made CNC Routers
    Anyone who owns a 6040 or 6040Z please chime in.
    We would like to share program settings ad any other info.
    Re: CNC 6040 6040Z - China Made CNC Routers
    6040z instructions from china mfg at ftp.computers-plus.net
    user CNC
    pass CNC#6040z
    Mar 2021
    This user/pwd not working now, it may have changed.
    Feb 2016
    Hello. At the end of this video you are showing where to put the wires for direction, 0-10V, and ground. do you have a picture of where the wires are going on your board? Mine is a JP-3136B. My black box is the same as yours (maybe not BOB though) A screen shot of ports and pins would be awesome but I might be able to figure it out from there.
    Regards,
    Gilles
    Complete guide to setting up a new 6040Z by a user, INETCoder.
    https://www.machsupport.com/forum/in...?topic=24497.0
    Does anyone know if there is a way to save the Mach3 setup to a file that can be shared to other users with the same machines?
    Make a shortcut on your windows desktop to this thread.
    Right click on the link below and choose copy shortcut
    http://www.cnczone.com/forums/open-s...ml#post1790768
    Right click on your desktop and choose new shortcut.
    Paste the resulting URL in location
    Click next
    Give it a name.
    Now you can get back here quickly.
    Parallel port should be set to EPP in bios for a 6040 or 6040Z.
    Driver is only available for 32 bit OS on parallel port units.
    Ask if you need help...
    Jan 2015
    75
    Standard DB25 to USB cables are serial, not parallel configuration.
    https://www.inventables.com/technolo...ion-controller
    The other option is an ethernet to parallel port cable/converter.
    MachForWin64 Kit - Ethernet Board for Mach on Windows 64-bit
    Mesa Electronics
    Not all connection cables are the same. You may need shielded cables in a noisy environment.
    How do you set the Mach3 software for parallel port cable/converter?
    Quote Originally Posted by Dean Elliott View Post
    The Mach3 driver takes over full control of the parallel port from Windows, the port is then subject to individual pin state read/write and no longer presents data, request to send and clear to send signals.
    USB converter cables (unless specifically manufactured for CNC control) are built to transfer conventional data and although they will run a printer perfectly well don't deal with the pin data in the way required for CNC control
    - Nick
    Jan 2015
    75
    Go to inventables and get a UC100 cable.
    UC100 USB to Parallel CNC Motion Controller: Amazon.com: Industrial & Scientific
    There may also be an Ethernet/parallel adapter.
    There are others, but they are expensive. Dave
    Dec 2016
    8
    I use Autodesk Inventor and Autodesk Artcam 2016
    May 2016
    Hi I am new to the 6040, I just received it 2 days ago. I am planning to put in a tinyg v8 and I am a little confused on where to plug in the VFD control wires into the tinyg. What is the AVI, COM and FWD for tinyg???
    Attachment 320680
    ^^^^that is the VFD control board
    Attachment 320682
    ^^^^that is the China CNC controller 6040
    Attachment 320684
    Sep 2016
    12
    I have a 6040 and it worked well for 5yrs. I recently had to change the spindle out 1.5K but the new on works in reverse. How do I change spindle direction?
    Feb 2009
    7
    Thank you for posting this video, very clear and helpful , Much easier to follow seeing it live, than just reading. Brilliant. Kind regards Mike
    Super easy way to make your g-code
    https://youtu.be/1WmCTWWlSbc
Page 1 of 3 123
  1. New 6040z-s80 from china
    By Reko666 in forum Chinese Machines
    Last Post: 12-10-2023, 08:50 PM
  2. China 3020 3040 routers
    By w7bcw in forum Chinese Machines
    Last Post: 02-07-2015, 05:08 AM
  3. GUANGDALY CNC ROUTERS FROM CHINA
    By rsi in forum Commercial CNC Wood Routers
    Last Post: 03-18-2012, 03:27 PM
  4. Made in Australia (Made in taiwan, china)
    By carbidecraters in forum MetalWork Discussion
    Last Post: 01-10-2006, 09:05 PM
