586,103 active members*
3,599 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hello!! Allarm 012 samsung cnc lathe PL25A
    Nov 2015
    Hello,
    are an Italian boy and are looking desperately for help, I hope someone can help me.
    I own a CNC lathe with Samsung PL25A samsung cnc, lathe l 'I used about two years ago and problems 0.
    Yesterday I was working a post I get allarm 012 unit spindle motor .... I try to reset but the engine does not stop immediately.
    I go to the electrical panel and hit reset on the inverter and the spindle stops, the inverter monitors the alarm was F100 (INVERTER OUTPUT CURRENT EXCEDEES THE VALUE )
    I do not understand what might have happened, never had problems with the engine, I restarted the spindle several times and noticed that goes into alarm when I exceed 1000 rpm, at low rpm nn nothing happens.
    In your dirt deposited in the channels of cooling of the engine can cause such alarm?
    Instead of manual lathe, it shows me as an overcurrent alarm 012 on supply of 2.5V.
    Where can I measure this overhang on the electrical system?
    The inverter is a Yaskawa 626vm3
    The rating plate of the motor:
    Yaskawa UAASKA-15CZ3N
    3 PHASE 4 POLES
    15/11 KW
    RATING 30MIN / CONT
    RPM 400/4800
    AMP 88/67
    sorry for the English but I'm using google translator
    thanks a lot
    Sep 2015
    25
    Re: Hello!! Allarm 012 samsung cnc lathe PL25A
    Quote Originally Posted by Erpatata79 View Post
    Hello,
    3 PHASE 4 POLES
    15/11 KW
    RATING 30MIN / CONT
    RPM 400/4800
    AMP 88/67
    thanks a lot
    Did you using this inverter still now. I need one help.
    Sent from my Moto G (5) Plus using Tapatalk
    Nov 2015
    Quote Originally Posted by harishmech10 View Post
    hello, I replaced the inverter with a regenerated one, unfortunately the problem is recurring, and I don't understand the reason. I changed the inverter, the remote control switch high low, but after about 30 minutes the error f100 comes out ..... now I am redoing the hydraulic pump motor, after about 15 minutes the heating and heating cycle is activated. I don't want him to disturb the inverter.
    Sep 2015
    25
    Hi friend. I'm also struggling lot with yaskawa drive. Kindly suggest what you exactly replaced and how you are running the machine currently.
  1. allarm overtravel
    By porcia in forum Fanuc
    Last Post: 01-27-2015, 03:37 PM
  2. help allarm overtravel
    By porcia in forum Mori Seiki lathes
    Last Post: 01-27-2015, 03:36 PM
  3. fanuc 369 allarm
    By jay d in forum Machines running Mach Software
    Last Post: 01-20-2014, 02:13 AM
  4. Samsung Lathe to network
    By bigbobr in forum USB, RS232, PARALLEL etc
    Last Post: 04-11-2013, 03:07 PM
  5. Samsung PL10 CNC lathe , Need Manual
    By Larken in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2008, 04:43 PM
