Re: PCNC1100 Spindle Shut Down Burring Cut
Originally Posted by
TXFred
I had the same problem, and Tormach gave me the answer.
The Power Draw Bar board has a mechanical relay on it. This relay is used to trigger the door switch circuit. Whenever the drawbar fires, this relay tells the VFD that the door is open, so that the spindle cannot start while the drawbar has the spindle locked.
Vibration causes this relay to fall open, which shuts down the VFD.
The solution is simple. Disconnect the drawbar board from the wiring to the spindle door circuit. It's not needed, because if the motor did try to start while the PDB was in use, the motor would stall and the VFD would shut back off, no harm done.
In fact, new version of the PDB omit this safety circuit because it's no longer needed.
But if you prefer to keep the circuit in use, you can order a later version of the PDB board that has a non-mechanical relay. This later version isn't affected by vibration.
Yep. ^ Chances are if it isn't the door switch it's the PDB. I've upgraded to the new latch as well as the new PDB board.
RAD. Yes those are my initials. Idea, design, build, use. It never ends.
PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
