586,655 active members*
3,985 visitors online*
Results 1 to 6 of 6
    Jan 2007
    723
    Add a charge pump to existing BOB?
    I need to add a charge pump to an existing machine to kill machine movements and the spindle starting when the computer is off. Ideally it would just be a passthrough board with a db25 male on one end and a female on the other that would just enable output when Mach sends its signal on pin 1 or whatever the default is.
    Has anybody seen such a beast? If so, where? If I can't find one that exactly meets my needs, what are my options for charge pumps without having to purchase a new BOB?
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Mar 2007
    2083
    Re: Add a charge pump to existing BOB?
    I guess your looking for some thing like CNC4PC's C4
    http://cnc4pc.com/Tech_Docs/C4r6_2%20USER_MANUAL.pdf
    the C4 does not pass the printer port signals
    what breakout board do you have , you may have an unused output you can use to with the C4 board
    for instance , with a 5 axis BOB and only 4 stepper drivers you could use the unused axis step or direction signal
    John
    24223
    If you feel like winding your own and If you have the Charge pump pin on the P.C. PP. you could use a simple 555 missing pulse detector.
    Use strip board and a couple of $ worth of components.
    There are probably many examples as the 555 is everywhere.
    Al.
    Albert E.
    Jan 2007
    723
    The CNC4PC solution isn't as plug-and-play as I would like it to be but I'm not afraid of wiring things up. I think I might just be able to use it to actuate an enable pin on the BOB I'm using.
    Al, thanks for the idea but when a pre-made solution is only $30, how can you say no to it?
    24223
    Quote Originally Posted by Pplug View Post
    Easy if it cost me $3.50 to make.
    Al.
    Albert E.
    Jan 2007
    723
    I get $40 an hour to work and this is at least an hours worth of work to get the parts(including prototyping board), wire the board, solder it and then install and test. That's if nothing goes wrong!
    I've been down this route before and it just doesn't pay in the long run. If the board cost $100, then we're talking! 😀
  1. Need Help (C4-Charge pump)
    By Barakathz in forum Maintenance DIY Discussion
    Last Post: 10-23-2011, 10:10 PM
  2. Charge pump help
    By Bradosb in forum Mach Software (ArtSoft software)
    Last Post: 09-12-2011, 06:37 AM
  3. Charge Pump
    By cadmonkey in forum LinuxCNC (formerly EMC2)
    Last Post: 04-06-2010, 07:19 AM
  4. charge pump
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-25-2009, 04:14 PM
  5. Charge pump
    By mlaws1172 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-04-2006, 05:46 AM
