586,104 active members*
3,398 visitors online*
Results 1 to 15 of 15
    Feb 2009
    328
    pathpilot homing crashes
    Installed pathpilot now if you home y axis it starts to home then rapids to crash if you rapid any axis it stops like it hit a limit switch and if you use the jog shuttle when you let it go the axis goes real slow for a bit? Not happy I made this switch yet but now i am in deep. Let me add my machine has zero issues.
    Feb 2009
    328
    Re: pathpilot homing crashes
    well after searching a ton I found a good artical showing that alot of tormachs mesa cards dont have the needed jumpers on them and mines one of them I just got this from ups a couple of days ago.
    Feb 2008
    644
    This is our fault (Mesa's) and I apologize for this
    As far as I know there are only a very few cards missing jumpers (all 6I25s)
    Yours is #2
    Jun 2006
    340
    PCW_MESA,
    So when I get my new PP Controller up and running, if I have the same problem how do I install the required jumpers?
    Bevin
    Jan 2007
    148
    6i25 manual
    http://mesanet.com/pdf/parallel/6i25man.pdf
    page 4 shows the default jumpers
    Feb 2009
    328
    Nice of you to admit someone on your end screwed up but don't take any blame you see I purchased this from Tormach not you so who's fault is it Tormach and only Tormach they should have much better QC then this. I will call them tomorrow morning asking for an overnight jumper package or a new board this has screwed up 3 days for me not to mention finding the issue. This could have screwed up my machine y axis crashed twice I don't go easy on things like this I need that machine up ready no matter what. Mesa might have forgot to put in the jumpers but Tormach has failed to post any type of warning to look out for this before your machine crashes?
    Feb 2008
    644
    Quote Originally Posted by bevinp View Post
    PCW_MESA,
    Bevin
    This is only an issue with a very few 6I25s from the last lot we shipped Tormach, so it is unlikely you will have a problem
    (if you use Tormachs controller those use 5I25s and there is no jumper problem with the 5I25s)
    Feb 2009
    328
    I would check no matter what im told my first home y axis started to go then rapid to a hard stop. Another way is simple it crashed my axis at full speed and kept trying to go about the worse thing ever on a machine.
    Jun 2006
    340
    PCW and cncbasher,
    In the meantime I found one of PCW's posts 20sep15 that had links to the manuals. Very helpful,
    And I applaud your honesty PCW. QC is not an easy function to keep at 100% level. Look at how many human mistakes occur in aviation/space industry in spite a very rigorous procedures.
    Bevin
    Jun 2014
    1780
    I had a problem with one of the later updates, in settings make sure the enable door switch is not checked, unless you have the enclosure from Tormach.
    mike sr
    Feb 2009
    328
    Yeah I have nothing checked.
    Feb 2009
    328
    What size, type, part number are the jumpers if tormach cant overnight them I can get them off amazon next day.
    Feb 2008
    644
    Quote Originally Posted by Tormachmaster View Post
    The jumpers are standard 0.1" (2.54 mm) type, here is an equivalent:
    969102-0000-DA 3M | Connectors, Interconnects | DigiKey
    Jun 2014
    1780
    I think those are .1 spacing, found on harddrives and computer related boards etc.
    maybe the comma was meant to be a decimal?
    mike sr
    Feb 2009
    328
    Quote Originally Posted by PCW_MESA View Post
    Tormach is sending me a set of jumpers for the board.
  1. PathPilot V1.6
    By adamboon in forum Tormach PathPilot™
    Last Post: 03-26-2015, 12:33 PM
  2. V27 Crashes
    By KSky in forum BobCad-Cam
    Last Post: 12-08-2014, 10:01 AM
  3. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  4. Bob cad Crashes
    By MLDatus in forum BobCad-Cam
    Last Post: 01-25-2011, 09:44 PM
  5. crashes
    By pyroshizzness in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2009, 06:27 AM
