586,236 active members*
3,131 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Defining 2.5D paths
    Dec 2011
    97
    Defining 2.5D paths
    I have spent quite a bit of time trying to figure out a good set of choices for machining a simple 2.5D part. I don't understand what a typical set of machining choices for this would be. I would like to mill a 0.050" pocket between some regions curves (seen in yellow on Region Curves attachment).
    What I would like to do is:
    1. Rough pass with larger tool leaving 0.005".
    2. Finish pass with the same tool leaving 0.
    3. Re-rough with smaller tool to get into corners and other areas where #1 and #2 couldn't reach without going over all the areas machined in #1 and #2.
    4. Finish pass with smaller tool
    I used 3P-Pocketing to do #1 and #2 with a 0.125" flat end mill. This looks fine and these paths are shown in the "Roughing and Finishing" attachment. (Side note: Why are 2.5D operations called "3P"?). In order to do step #3 with a 0.03125" flat end mill, I have tried many things. One operation which doesn't work is Z-level Remachining. This didn't cut into the corners left by the larger tool and there are many strange ramp-ins and outs in the middle of what should be straight lines. This is shown in the "ZLevel Remachining" attachment.
    Re-Roughing instead of Z-Level Remachining also does not cut into the corners. ("Reroughing"attachment)
    Mar 2004
    1661
    Re: Defining 2.5D paths
    Pocketing and contouring, that's what I use for these kind of things. Unless it's a small part then I let the 3D features do the work.
    (It's called 3P because it is 3-axis Profiling)
  1. Defining a chamfermill?
    By colton_m in forum Mastercam
    Last Post: 09-27-2014, 06:01 AM
  2. Defining stock
    By scottsss in forum SprutCAM
    Last Post: 11-09-2013, 01:00 AM
  3. defining corner types v24
    By LGSM3 in forum BobCad-Cam
    Last Post: 07-15-2013, 03:37 PM
  4. DEFINING MOMENTS IN EVERY CAREER
    By Joberate in forum Employment Opportunity
    Last Post: 01-28-2013, 09:52 AM
  5. Defining Tooling
    By deadeye_sd in forum Dolphin CAD/CAM
    Last Post: 02-21-2008, 02:27 PM
