586,121 active members*
3,675 visitors online*
    Jan 2007
    7
    Belmont Hole Popper
    Hello Guys,
    I just bought a Belmont Hole Popper, used of course. I'm new to this type of machine.it comes with a ebbco dionizing unit and chiller. I've been told that you can use tap water or dionized water. Is this true? Is there anyone in here that is familiar with this type of machine. I believe it's a Maxsee S-26.
    Thanks in advance.
    Wiredude
    Dec 2012
    108
    Re: Belmont Hole Popper
    Wiredude, you can fill your tank with tap water but you would need to circulate it a while to deionize it before you burn. How do you fill your wire reservior? We have leased DI tanks for the fill water to keep the resin usage under control.
    Oct 2005
    859
    You can also bypass the provided de-ionizing tank that uses bags from the in and out lines to hook up a DI tank. We use electrodes inc. for our tanks as they provide virgin resin.
  1. moving hole made using hole wizard SW2011
    By themotorman in forum Solidworks
    Last Post: 11-16-2014, 05:51 PM
  2. Replies: 9
    Last Post: 09-18-2012, 12:11 AM
  3. How do you edge find with your hole popper?
    By vfsi in forum EDM Discussion General Topics
    Last Post: 06-07-2012, 08:34 PM
  4. Replies: 18
    Last Post: 03-21-2011, 11:28 PM
  5. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
