586,493 active members*
1,068 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > thin part machining problem
Results 1 to 1 of 1
    Jun 2010
    86
    Hi
    please see attached drawing.
    It is a seal ring that split from center, i machining this part with my CNC lathe machine by this method :
    1- Cutting a ring from a plate ((ST37 material(ASTM A 283 M-98 Grade B))
    2- Turing a simple ring with 10 mm bigger than the original dimension
    3- Stress relive
    4- 5 to 6 mm Bobbitt coating material for inside of part
    5- cut the part from center by wire cut EDM machine
    6- Turing the ring 1 mm near the original dimension
    7- put the part 3 to 4 day with out any job on it in the room temperature
    8- Final machining
    I did all eight up step for my seal ring but after opening the part from My CNC lathe i have some problem on my part (The dimension on the one side of ring has changed, i seemed i have stress on part that after opening the clamp from the machine it is relived and changed the dimension of my part
    I clamp the ring by using adjustable support plate on my CNC lathe not with 3 or 4 jaw self center
    please let me to know what is wrong with me if you have any experience in these parts.
    Thanks a lot
    Attached Thumbnails Attached Thumbnails 011.png   Mechanical_Seal_Ring_Vertical_1.jpg
  1. Machining polycarbonate to a very thin thickness
    By thecncnewcomer in forum Material Machining Solutions
    Last Post: 06-18-2014, 04:47 AM
  2. Thin walled part
    By maz43 in forum MetalWork Discussion
    Last Post: 06-15-2009, 10:51 PM
  3. Turning a Thin part and Getting a Bad taper
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 02-27-2009, 04:26 AM
  4. thin plate machining
    By tmt_92021 in forum MetalWork Discussion
    Last Post: 10-24-2006, 01:54 AM
  5. Problem machining accurate size part on my Bridgeport CNC conversion
    By fastturbovet in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2005, 06:01 AM
