586,060 active members*
4,328 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > how to connect( hydiv268n-5a to mach 3 5 axis board
    Dec 2015
    7
    Angry how to connect( hydiv268n-5a to mach 3 5 axis board
    hey every one
    it is a really problem
    because i hade one driver is gone .........
    so i need the correct connection and all the photos from internet not have that compaination
    the driver is ((( http://www.cnczone.com/forums/attach...d=300252&stc=1 )))
    the interface board is ((( mach 3 5 axis board )))http://www.cnczone.com/forums/attach...d=300250&stc=1
    i hope some one help me
    May 2005
    1397
    Re: how to connect( hydiv268n-5a to mach 3 5 axis board
    Why not contact the people you purchased the units from? Don't they offer technical support? I always support the units I sell...
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Mar 2018
    Hello
    I have the same 5-axis board and the same driver.
    Could you tell me how you connected?
    Thank you very much.
    Mar 2007
    2083
    for each stepper driver you can either
    connect all of the step + and direction + terminals to the +5V supply to the breakout board
    and the step - and direction - to the appropriate BOB outputs for the axis
    setting the outputs to active low in mach3
    or
    connect all of the step - and direction - terminals to the 0V / ground supply to the breakout board
    and the step + and direction + to the appropriate BOB outputs for the axis
    setting the outputs to active high in mach3
    John
  1. Trying to get Mach 3 to connect to outputs
    By wld99 in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2022, 12:19 PM
  2. How can i connect a HY VFD with MK 2/4 PROBOTIX board?
    By shanu4454 in forum Phase Converters
    Last Post: 09-21-2014, 04:19 AM
  3. 4 Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question
    By s_sus in forum Stepper Motors / Drives
    Last Post: 04-29-2012, 06:36 PM
  4. 5-Axis CNC Stepper Motor TA8435H Driver Board Mach 2 3 question
    By aashijanani in forum Stepper Motors / Drives
    Last Post: 03-19-2010, 06:39 PM
  5. How to connect ELM Board and OSMC Board ?
    By bigeye3107 in forum Open Source Controller Boards
    Last Post: 06-16-2008, 12:26 PM
