586,119 active members*
3,472 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Spindle speed for involute gear cutter
Results 1 to 5 of 5
    May 2018
    3
    I just got the Mill Arbor for a Sherline Mill and need the know the spindle speeds for a 16DP 55mm HSS involute gear cutter set. The big machines run these cutters slowly, around 100 RPM but I don't think the little Sherline motor can generate enough torque at that slow of a speed. I have tried light cuts and higher speeds seem to cut better but I am afraid to damage the cutter with a long series of cuts until I have more information. I am cutting Delrin, 6061 Al and Brass.
    Nov 2009
    4415
    Re: Spindle speed for involute gear cutter
    feed per tooth?
    A lazy man does it twice.
    May 2018
    3
    An FpT of ten thousands should work for Alu and Brass and given that the cutter is 2.17 inches dia then rpm = 12 / 3.1416 x cutting speed/2.17 should give a usable spindle speed should it not? (assuming a cutting speed of 600 for Alu and 350 for Brass)
    Jun 2011
    692
    Your speeds seem a bit aggressive, I think I'd halve them to start if you can. If you're losing torque going that low, those speeds should work, but on the brass you may see the tools wearing faster.
    10 thou per tooth seems very aggressive for a little machine like that. I guess there is a lot of chip thinning and not a lot of material being cut, but I'd think 2-4 thou per tooth would be a lot safer.
    Are you climbing or conventional?
    May 2018
    3
    Quote Originally Posted by skrubol View Post
    Yes after reflecting on what you said I am definitely running to aggressively to try to compensate for lack of torque. It seems to do just fine with lower speed and feed and the chips look better. I use conventional direction milling. There is definitely not enough torque for climb milling at this low speeds with that big involuted bit. Thanks for the input
  1. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  2. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  3. Cutting a 10 tooth pinion gear with involute cutters
    By ftkalcevic in forum MetalWork Discussion
    Last Post: 07-19-2011, 12:29 AM
  4. Lazy Cam and Involute Gear Generator
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 04-18-2011, 03:09 PM
  5. 2-Speed Gear Box a Necessity?
    By JMFabrications in forum Haas Mills
    Last Post: 03-21-2008, 09:47 AM
