586,070 active members*
3,514 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Maztrol M32 Meldas MR-S1, MR-S11 AC servo AMPLIFIER analog speed input on VQC 15-40
    May 2012
    19
    Hello
    I just finished cleaning an old VQC 15-40 produced in 1989 CNC machine after a few years of storage (one in our warehouse) and found out that both backup batteries are not functional. I did reinitialize the Meldas controller and unfortunately found that the system diskette was unreadable(I also tried to read it in a PC with omnifloppy without success).
    The unit has MR-S11-80-E31 on X axis and MR-S1-80-E31 on Y,Z axis AC amplifiers with optical encoders on the motor shaft and closed loop optical encoders on the ball screws.
    Because of the missing disk and out-of-date system I am planning to retrofit the CNC with LinuxCnc and analog output Mesa cards (which I already own).
    The problem I have is lack of info regarding the servo drives.
    I did found on the Mazak MR-S maintenance manual an Analog speed input pin but no info regarding parameters, jumpers or other way to enable this input.
    Anyone has some info about were to find info about these drives or if it is possible to use an analog input on the servo drives or a way to control them from LinuxCNC ?
    Razvan
    Oct 2003
    321
    Quote Originally Posted by rirazvan View Post
    Hello
    Razvan
    Hallo,
    Where is your Shop?
    Best regards
    Stanko
    May 2012
    19
    Re: Maztrol M32 Meldas MR-S1, MR-S11 AC servo AMPLIFIER analog speed input on VQC 1
    Our workshop is located in Bucharest.
    May 2017
    Where you able to integrate the MR-S1 servo controllers with the LinuxCNC/MESA board set up? I would like to do the same.
  1. Problem with Analog Input mode
    By speedydumpster in forum CNC Machine Related Electronics
    Last Post: 05-14-2012, 07:03 PM
  2. Question about analog input on servo drive
    By jsheerin in forum Servo Motors / Drives
    Last Post: 12-10-2011, 04:25 AM
  3. analog input VFD speed Hitachi SJ100
    By Karl_T in forum Phase Converters
    Last Post: 11-22-2008, 10:09 PM
  4. Analog Input for Devicenet Hitachi SJ100DN2
    By SirThadious in forum Phase Converters
    Last Post: 02-07-2008, 10:58 PM
  5. How to drive Analog Servo Input +/- 10V
    By gurvy in forum CNC Machine Related Electronics
    Last Post: 05-31-2007, 05:31 AM
