586,035 active members*
3,828 visitors online*
IndustryArena Forum > CAD Software > Autodesk > autocad dwg 2010
    Dec 2015
    autocad dwg 2010
    I have several drawings that were created in autocad 2010. However now I am using 2012, and the files will not open, and I get a message from autocad indicating that I need the DWG viewer to open the file. I downloaded the application, and installed it from the autocad website, but when I execute it, I get the attached error. Does anyone know if the view works with Win 7? Or a way to open and print my drawings?
    Re: autocad dwg 2010
    Newer versions of AutoCAD should open ALL older version files. Not sure what your problem is, but re-read the error message.
    Jan 2011
    188
    that sounds like when you try to open a DXF in windows or in a browser - open the file using the open command from inside autocad - it should open correctly or display a clear error message -
    www.signtorch.com
    Dec 2015
    In case threads and the guide aren't effective, then try to use more powerful solution for complicated AutoCAD corruptions https://www.openfiletool.com/dwgopen.html DWG Open File Tool
    • Try to open the drawing file directly instead of using the Recent Documents menu.
    • Check that the storage location that holds the drawing is working properly.
    • Use the RECOVER and RECOVERALL commands on the drawing.
    • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
  1. Replies: 1
    Last Post: 03-02-2014, 03:06 AM
  2. AutoCAD & Inventor 2010 Shared Network Issue
    By RoboFutbol in forum Autodesk
    Last Post: 07-21-2010, 04:02 PM
  3. edgcam 2010 and inventor 2010
    By inflateable in forum EdgeCam
    Last Post: 03-22-2010, 09:03 AM
  4. Replies: 4
    Last Post: 12-28-2009, 11:12 PM
  5. AutoCAD 2000 to AutoCAD LT 2010?
    By 2kjettaguy in forum Autodesk
    Last Post: 08-15-2009, 03:33 PM
