I'm working with drawings with surfaces brought in from another business. I have a 3d model imported into mc9 that has holes and counter bores in the middle of a nurbs spline surface (airplane wing type shape). When I generate a program it treats the edges of these holes/c-bores as an edge of that particular pass instead of just continuing on across the hole in a smooth pass. I have several little volcanoes in the middle of the surface I'm trying to cut.
How can I modify the surface in MC9 to eliminate these holes/c-bores so that my program passes are smooth across the entire path instead of broken at the edges of these holes?
I've been working with various versions of MC for almost 25 years but I don't have a lot of experience with full 3D in MC and almost none working with surfaces. Most of my 3D programming is just linear straight along a wire surface with no hills and valleys in the surface, no shapes.
Thx
JohnF
