Hi guys same ol noob problem i am setting up my first cnc and i bought hoss's upgrade for the g0704. With that being said there is no info in the package on how to set up mach 3 to my c10 breakout board so im gonna list all my hardware below and tell you how far ive gotten so far in hopes that someone can point me in the right direction.
1 nema 34 kl34h295-43-8a
2 name 23 kl23h2100-35-4bm
1 c10 breakout board
1 kl 8060 keling stepper driver
2 kl 6050 keling stepper driver
and a 48 v 12.5 amp power supply kl - 600 - 48
so i have all my drivers setup in windows xp 32 bit with parallel port working fine and dandy have my host address from the resources input page into mach 3's ports and pins (along with declaring what pins do what for all 3 axis's) and everything seams to be working. I hit the c10 pinouts with my volt meter and seen in mach 3 when i push left or right i see a +.032 v on the pull and either a +5v or 0v for the direction depending on what direction i press.
So to me i have good communication between my computer and c10. My problem is i have no output into my motor? would this be a mach 3 problem or a controller / wiring problem any advise would be helpful at this point.
