Ran into a problem and need help.
I use my cnc once every couple months, so it will sit untouched for periods at a time. Yesterday I started it up, loaded a program thru the serial port. Jogged all 4 axes, set tool lengths, and fixture origin. Push 'home 1' button, and nothing.... flashes something real quick, and instructs me to jog to cs position and cs. I do, then auto, start program. It starts 1st line of code, then shuts down and scrolls same message. The quick flash of a message says 'updating memory '. I went ahead and left the cnc one for a few hours and retried this morning....same result.
One more thing... when I press jog, the values are moved from the cs position. example.... x.0003 y-.0006 z0 a .0040
Hoping this is an easy fix.
2000 Fadal vmc 3016l
cnc-88hs controller
422k memory
4th axis, ridgid tap
Any advise is appreciated,
Javier
