Originally Posted by
lrgoodger
I've been researching ballscrew thrust bearings non-stop since my previous post and I have learned a ton. I learned that new ones are too expensive for a retired hobbyist on a fixed income like me. I have discovered the answer to most of the questions in my previous post, so now the question is changed.
Since I already have zero backlash on both X and Y axes, the only reason for replacing these bearings is that I can feel that they are in distress (feel 'gritty' when turning by hand) and would likely not last long under regular use (which I won't do anyway). I think the Y axis would last as long as I will, so I'm not going to do anything with it. The X, however, is very gritty and may not last long at all, so I want to do something with it while I have the machine disassembled. In other bearing applications where they were un-shielded or had a removable shield, I have flushed out the gritty debris in them and had them perform fine afterward. This prompts new questions.
First, do the 3M9110W1H X axis bearings have removable dust covers? I discovered that the spindle bearings do when I went through the head (but I don't know about the Z axis thrust bearings since I didn't remove them, thank goodness).
Second, presuming I can successfully wash out the bearings, how do I get the preload back to where it is now? The fact that the bearing nut is staked on is going to require a lot more torque to remove it than what the preload alone would require, so I can't just measure removal torque and re-torque to that same value. I feel if I do that, I will have too much preload.
If I bite the bullet and get new X axis bearings, how would I know how much to torque them to set the preload?
Ron
