I recently bought a used Clarke Vacuum Former. It came with a 30 amp 125v plug. I am going to wire up an outlet for the machine but want to make sure this is the correct plug.
This is the data sheet from the company. http://crclarke.com.au/crclarke/imag...cument/750.pdf
Should I use a 30 amp breaker? Should I continue using the 30 amp plug?
