586,071 active members*
3,777 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Hardinge out of stock on X axis bearings - what now?
    Nov 2015
    8
    I got the X-axis ball screw bearings off and they need replaced. The BP number is 1770060. Hardinge lists them at $700 but they are out of stock. Is there an alternative?
    Nov 2004
    164
    Re: Hardinge out of stock on X axis bearings - what now?
    I don't think Hardinge really is interested in providing service or parts for the older machines. The guys at BptParts.com - Bridgeport & CNC Machine Replacement Parts have provided me Bridgeport parts and knowledge over the years. You should also be able to get them easily from any bearing distributor like Applied Industrial Technologies or Motion Industries. Just have your local distributor stop in and cross them if they don't have the mfg. part number stamped on them. My Torqcut 30 bearings were conveniently marked on the OD with INA P/N ZKLF 2575.2RS. I got lucky and scored off some off of Ebay for brand new INA bearings for between 1/2 to 2/3 the price. But $700 sounds about right for a good quality ball screw bearing.
    15362
    Quote Originally Posted by lrgoodger View Post
    It depends on what machine you have what axes the Bearings are for, some of the Bearings are not an off the shelf bearing and are totally custom for your Bridgeport machine
    BptParts are your best choice
    jmullett That was a good find INA P/N ZKLF 2575.2RS, that's one of the hard one's to find now
    Mactec54
  1. Replies: 0
    Last Post: 12-04-2015, 08:25 PM
  2. Conquest 42 Hardinge Tail Stock Problem
    By Dwayne Foy in forum Hardinge Lathes
    Last Post: 05-25-2012, 02:53 AM
  3. Hardinge CS-51 x/z axis will not home
    By ZenoTech in forum Hardinge Lathes
    Last Post: 09-26-2011, 06:44 PM
  4. Grizzly (G8688) 7x12 Head Stock Taper Bearings
    By Danny X in forum Mini Lathe
    Last Post: 05-27-2011, 10:05 AM
  5. Hardinge with Siemens 810T 3-axis
    By topcnc in forum Hardinge Lathes
    Last Post: 09-09-2010, 04:08 AM
