586,077 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > z axis encoder error! arrow 1000!
    Oct 2008
    16
    I have a problem with an Arrow 1000 that keeps putting out "Z axis encoder error." Is there a scale in the Z axis that i can clean? Or if i change out the servomotor will that help?
    Dec 2006
    584
    Re: z axis encoder error! arrow 1000!
    Do you have a scale on the Z axis??? If so then the problem is with the dirty scale and it needs to be carefully cleaned when taken apart. DO not scratch the glass!!!! This is a common problem with scales and the problem should not be in the motor encoder.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Arrow 1000 Y axis problem / Vickers AS10300 codes
    By Chaz in forum Cincinnati CNC
    Last Post: 02-24-2020, 08:31 PM
  2. Cincinatti Milacron Arrow 1000 Tooling Error
    By david_culler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2015, 01:10 AM
  3. moving an arrow 1000 4 axis
    By slowlearner in forum Cincinnati CNC
    Last Post: 08-04-2014, 01:27 PM
  4. cincinnati arrow 1000 realtime timeout error
    By stuart wiezniak in forum Cincinnati CNC
    Last Post: 04-24-2013, 10:26 PM
