Originally Posted by
weekend_warrior
***SOLVED*** for those that are currently experiencing the same problem as mentioned here I've found the solution. Its actually REALLY simple. When you first install mach3 and/or Ethernet SS you get the error (Emergency Stop not assigned). If you go into (ports and pins) and attempt to change any setting prior to first setting the emergency stop it will lock Mach3 up. Assign the emergency stop in ports and pins, and then click apply, then OK and restart mach3 so the settings are wrote to XML. Once restarted you can then make the appropriate changes needed in ports and pins without it locking up. It's seems that this may be some sort of bug that it you attempt to change any setting prior to assigning the emergency stop once you close ports and pins, mach3 throws a fit trying to recover from not having the emergency stop assigned yet. I've successfully managed to get 062 working using this.
