586,071 active members*
3,900 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > Distinguish between structural steel (S355) and Cromoly (CrMo)
    Jun 2008
    113
    Question Distinguish between structural steel (S355) and Cromoly (CrMo)
    Our shop mainly deals with common steel (S355) and chrome-moly (42CrMo). To this day, I haven't found a realiable method to tell the difference between the two when using hot rolled bars. I have tried toughness testing (hammer-rod etc). and spark testing ,but I simply cannot tell the difference. Taking a chip with the machine seems to be the only way (machined chromoly surface is brighter). Of course the steels should be stored separately, but it simply does not work here.
    What's your suggestion?
    Jan 2015
    138
    Re: Distinguish between structural steel (S355) and Cromoly (CrMo)
    A spark test should do it. Did you try comparing the sparks to known samples? I know of a guy who has a key ring of maybe a dozen different steels, labeled for spark comparison.
  1. JOB OPENING - Service Engineer - Structural Steel Fabrication
    By coalstove in forum Employment Opportunity
    Last Post: 09-16-2014, 03:20 PM
  2. JOB OPENING FIELD SERVICE TECH Structural Steel Industry
    Last Post: 09-16-2014, 03:06 PM
  3. Replies: 0
    Last Post: 03-26-2014, 09:20 PM
  4. Machining S355J0 Structural Steel
    By wganders in forum Material Machining Solutions
    Last Post: 07-29-2009, 08:01 AM
  5. Sources for Structural Steel
    By ChrisJ in forum Welding Brazing Soldering Sealing
    Last Post: 08-11-2005, 12:35 PM
