586,076 active members*
3,865 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Project Curves Engraving Problem in Simulator
Results 1 to 8 of 8
    Mar 2010
    45
    I am trying to engrave/machine text into part. I've tried a couple different scenarios and they all wind up with the cutter taking shortcuts in the simulator and going through the part. Most areas it picks up and traverses to new starting point but in a few instances it just connects two curves (text objects) together. Instead of dotting the "i" it makes a "I" and the "t" has a nice little triangle on top, and a few letters and numbers are connected etc. Any recommendations on how to prevent this. I've gone to the simplest font possible, started out with fancy font and doing boolean diff to do more machining but now I just want something to work simple then I'll attempt to advance my skills here... Oh I even ungrouped the text and tried to do it one Projection curve at a time and I still had some issues in the simulator.
    Any help would be appreciated. Thanks!
    Mar 2004
    1661
    Re: Project Curves Engraving Problem in Simulator
    I am using Project Curves all the time, would you mind uploading a simple model you have problems with and I can have a look?
    Mar 2010
    45
    Here is rhino file, just simplClick image for larger version.
ID:	301064e christmas ornament to give away... 2 files included one with "fancy font" and one with simple. Here is a shot of simulator showing issue as well.
    Apr 2003
    1357
    You need to go into your tool library and reduce the cut link distance. Make it something small like 0.01mm (.0004"). That might be a bit extreme, but it will definitely force retracts at the end of each segment.
    Attachment 301084
    Also, if you raise the box top a bit, and then check off the "Retract to box top" checkbox, you will get nice clearances between letters, but no wasted approach time if you keep the safe clearance height low. Here is my settings (in metric):
    Attachment 301082
    Hope this helps,
    Dan
    Mar 2004
    1661
    @Dan, not Along Curves, is Project Curves.
    I tried one of your files and I just took a cutter from my library (that has cut-link set to 1 by the way).
    These are the settings I used in Project Curves. Please note that the cut is deep because I didn't simulate a surfacing, I'm cutting in the raw material so to speak.
    Apr 2003
    1357
    Hi Sven, you are correct, I missed that. I still think the OP should look at his cut link distance. If the value is too great madCAM will try to eliminate retracts and join the curves.
    Dan
    Mar 2010
    45
    Hi Dan B and svenakela,
    Thanks for info and quick response. Dan's "link" setup did the trick in the simulator. sadly I went to go run it and right after I got it setup I had a problem with the drawbar on the tool holder so I've been busy tearing that down to repair in an attempt to make Santa Claus deliveries! It's tough trying to be an elf, LOL... Today some new 8mm air line is supposed to arrive so hopefully tonight I'm operational again and can test it out. Sadly 8mm air line is not widely available in the USA locally. I'll provide additional feedback once I have it running.
    Additional Comment/Question:
    Just for my understanding the way I interpret the "link" setup is it is looking at a min distance between similar features to "retract" otherwise it will "connect" them... is this a fair statement of this config?
    Thanks again.
    Mar 2004
    1661
    Yes, that's a correct assumption.
  1. MDF Racing car simulator project.
    By ynneb in forum Wooden Clocks
    Last Post: 05-21-2020, 04:33 AM
  2. Curve milling along curves, simulator?
    By jeanyes in forum MadCAM
    Last Post: 03-08-2014, 03:16 AM
  3. Racing Simulator Project
    By MiNeM in forum Hobby Discussion
    Last Post: 05-03-2012, 01:52 PM
  4. Home Simulator Project
    By Atomic_Sheep in forum Hobby Discussion
    Last Post: 05-11-2010, 02:22 AM
  5. problem in cutting curves
    By fawzy_mahmoud in forum Linear and Rotary Motion
    Last Post: 12-13-2006, 10:26 PM
