Re: Dm542a and 23hs9430B stepper motor setup for MACH 3
No offense intended but I think that reading the Mach3 manual would be the best place to start Product Manuals - Newfangled Solutions
With regard to the Velocity setting it is 'trial and error' - just increase until the motor stalls (at fast jog) then reduce setting by 30% and save. Repeat for each axis.
Acceleration should be treated in a similar manner remembering that higher Acceleration (possibly at the expense of reduced Velocity) will give less corner rounding when operating in Constant Velocity mode. The manual explains.
Tweakie.
CNC is only limited by our imagination.
