586,060 active members*
4,606 visitors online*
Results 1 to 7 of 7
    Mar 2012
    27
    Question 60 Watt CO2 Laser Deck
    Can someone please tell me what the best materials are for use as a laser deck or bed?
    Jan 2008
    940
    Re: 60 Watt CO2 Laser Deck
    mine has an aluminum plate and a honey comb piece on top of that
    Mar 2012
    27
    Any idea how hot the laser beam is where it hits the target? Or the Watts per square cm or inch for the beam. I realize the beam is much smaller than that.
    Jan 2008
    940
    not sure how hot it is but a CO2 laser won't cut metal the honey comb is there to keep the piece that I am cutting up so it cuts clean
    Mar 2012
    27
    I've heard of folks using Aluminum for a back stop. Won't the aluminum reflect the beam to some extent? I want the beam, if not absorbed by the target, to be absorbed by the backstop and not end up banging around inside my laser cutter box, looking for a way out....
    Feb 2010
    155
    The laser (depending on the lens size) starts to defocus and lose power rapidly past the focal point, so it won't "bang around" inside your laser box. For example, with a 2" focusing lens, on 1/4" thick acrylic my laser is already starting to cut a slight hourglass shape on the lower portion of the acrylic. Any reasonable distance below the the part you are cutting is probably sufficient to prevent any strong reflections. You can test this out yourself by cutting a part with the laser at varying heights, and you will see how large and weak the laser gets when you increase the distance.
    I use a pin table made from perforated steel with 1" long roll pins hammered into the perforated holes, and there are no black/scorch marks on the steel. See this thread for pics.
    http://www.cnczone.com/forums/genera...ml#post1773016
    Mar 2012
    27
    Thanks for your help. I ordered the metal honey comb and it works fine. Just for peace of mind and placed a welding blanket on the deck below the honeycomb to absorb and errant laser. Thanks again!
  1. Replace 30 watt C series epilog laser with 60/55 watt C series tube
    By jrich in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-25-2014, 07:00 PM
  2. Need help with 130 watt chinese laser
    By upd in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-03-2013, 05:53 PM
  3. LTT 50 Watt Laser
    By cure1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2011, 11:35 PM
  4. 35 Watt Laser Engraver
    By Etches in forum Engraving Machines
    Last Post: 09-15-2008, 12:16 PM
