586,082 active members*
3,563 visitors online*
    Dec 2015
    60w China Laser will engrave but not cut.
    So I just got my machine and I can't get it to cut but it will engrave. I am using RDWorks to send the job to the laser. I created a box, and then set the laser to 10mm/sec and 60% power. When I run the Job, it goes through the movement but the laser does not turn on. If I load a jpg and go to scan/engrave, the laser turns on and engraves.
    Strange. Is it in the RDWORKS software or the software on the machine?
    Brand: Vevor
    Model: 750LEM
    60W CO2 USB Laser Engraving Cutting Machine ENGRAVER Cutter Woodworking Crafts | eBay
    Aug 2009
    655
    Re: 60w China Laser will engrave but not cut.
    There is another thread that just resolved today with issues from RDcam to laser. It should have plenty of steps to look at. Since a bunch of us just went through things there, it seems redundant to post it here. Look in the today's posts and you should see it (as of today at least).
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. China laser started firing laser during rapid moves
    By Billn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-21-2016, 06:32 AM
  2. laser fails to fire on philicam twin laser from china
    By paul1965 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2015, 01:53 PM
  3. Replies: 49
    Last Post: 10-31-2014, 02:00 AM
  4. I need a laser engrave
    By flinstone in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-21-2011, 06:57 AM
  5. How to engrave pcb with laser
    By codes in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2008, 09:23 PM
