586,042 active members*
3,756 visitors online*
Thread: Custom Motor
    Dec 2015
    4
    Custom Motor
    NC Cams, your inbox is full. Hopefully you can chime in here.
    I'm working on an oddball project. Take a 4 pole induction motor, press the shaft out of the rotor, hog out the rotor ID for a larger hollow shaft (without getting into the squirrel cage), press the rotor back onto a new shaft. I've done the homework electrically and it will work with a small loss in power. The motor is for driving a portable lathe which needs a large pass through hole for the work being done.
    The shaft is connected directly to a chuck in a spindle-less setup. The shaft is 1/4" thick 4140 tubing, internally tapered at the front to accept ER50 collets. The rear may run a fan or a pulley, I haven't yet decided. Motor will turn up to 7K RPM for short runs from a VFD.
    The original plan was to install these bearings in custom face and rear plates:
    50x80x16,MR6010C-ZZ/C3 #5 EP2 EMQ,Metric, Electric Motor Quality (EMQ) Bearings
    but NC Cams' posts have made me reconsider this, especially in the thermal expansion department. The 50mm ID is about the practical limit price-wise as large ID bearings go. The next size up doubles in cost, the next triples, etc. Initial plan was a press fit against steps on the shaft and a press fit of the races in the end plates, with either shims or bolts in the plates for preload.
    I think it would be wise at this point to ask those more in the know how you'd do it before I end up smoking $250 in bearings.
    24221
    Re: Custom Motor
    Unfortunately NC Cams passed away a few years ago.
    Al.
    Albert E.
    Dec 2015
    4
    Re: Custom Motor
    I'm very sad to hear that, Al. Not because of my little project, but because the world is now lessened.
  1. WTB Custom ATC Spindle Motor
    By Feeler_Gauge in forum Want To Buy...Need help!
    Last Post: 04-05-2015, 01:41 AM
  2. Custom Stepper Motor End Caps
    By rkward in forum Stepper Motors / Drives
    Last Post: 06-22-2014, 09:13 AM
  3. Custom Gear Creation Wanted or Replacement Stepper Motor- UK
    By outbreak123 in forum Want To Buy...Need help!
    Last Post: 05-28-2010, 11:27 AM
  4. who rebuild dc motor?custom servo motors
    By vdude in forum Milltronics
    Last Post: 03-04-2009, 11:11 PM
  5. RFQ Custom Motor Endcaps
    By JustinM in forum Employment Opportunity
    Last Post: 07-20-2006, 07:03 PM
