Hello CNCZ'ers,
I'm new here, and new to CNC in general. I don't feel like I belong on this forum with all of you talking in jargon that I don't yet understand, but I seek advice from the experts (or anyone who knows more than me), so if you are willing, I would be forever thankful for the help.
OBJECTIVES
1) Cut monogram out of 1/8" aluminum sheet.
2) Bevel edges of monogram at 45 degrees.
EQUIPMENT
Next Wave Automation Piranha FX with touch plate. Software: VCarve desktop.
Amana Tool 8-pc Set No. AMS-134
PROBLEM
I don't really know where to start. I've done a considerable amount of research and am prepared to do more, but I was hoping to get a little guidance from the experts as far as the general direction I should be headed here.
We sell custom display axes with an 1/8" aluminum inlay 1/16" recessed into the hickory handle. So far, I have hand cut 33 monograms out of 1/8" aluminum with a band saw. Then I hand file the edges smooth, then add a 45 degree bevel with a file, but as you can imagine this takes a considerable amount of time with less than ideal results. I purchased this Piranha FX router CNC machine in hopes of making this project more efficient.
As you can see from the photos, the monogram emblem is bent; however, I plan to continue doing this step by hand. I'm only looking to cut and bevel the monograms out of a sheet of aluminum.
QUESTIONS (Here I'm going to show just how little I know)
1) Do I need to place MDF under the aluminum sheet or is it precise enough to where I don't need to worry about it making contact with the table?
2) Which bit or bits should I use? (hopefully one of the bits in the Amana 134 set will do the trick)
3) Which grade of aluminum is ideal?
4) I have a 2D vector of the monogram, but will it be necessary to replicate it in a 3D program for the beveled edge or can I accomplish this with VCarve Desktop?
Thank you in advance!
-Jay
