586,060 active members*
4,569 visitors online*
    Mar 2009
    30
    Hypermill 3+2
    In Hypermill, is 3+2 (X,Y,Z machining on a part tilted around B and C axis) part of the normal 3 Axis milling package? It is very unclear from their website and brochures. I am looking at adding a rotary 4th with a trunnion table to a VMC. On the trunnion table, we will have a zero point fixture which can be precisely rotated in 90 degree increments. All machining would be done with the part indexed. No simultaneous motion. I am very interested in HM in SW, but there is no way I can pay for a full 5 Ax program for a 3 Axis VMC.
    Other software, for instance HSMWorks, very clearly make 3+2 part of the 3 axis package.
    Apr 2006
    130
    Re: Hypermill 3+2
    hyperMILL 2-axis or 3-axis cycles can be used with general frame (approach vector). No added tool paths required for 3+2. There would be a need for multi-axis postprocessor instead of your existing 3-axis vertical spindle PP.
    Mar 2009
    30
    Re: Hypermill 3+2
    Quote Originally Posted by Alan L View Post
    Thanks for clarifying. I thought that was the case, but when reading the HM marketing data, they only mention 3+2 in the 5 axis brochure.
  1. Hypermill and Mach 3??
    By CyborgCNC in forum Hypermill
    Last Post: 10-20-2015, 08:00 AM
  2. pro-e - hypermill
    By yaman in forum Hypermill
    Last Post: 06-22-2009, 06:37 PM
  3. as a study HYperMill
    By spoiled in forum Hypermill
    Last Post: 05-26-2008, 05:17 AM
  4. hypermill in amd
    By rokpyle in forum Autodesk
    Last Post: 11-20-2003, 10:44 PM
  5. anyone use hypermill
    By rokpyle in forum Uncategorised CAM Discussion
    Last Post: 08-13-2003, 01:05 PM
