@the.sniper
Sorry. I think I'm confusing things here.
The that was in solution in my water now seems to have come out, and I no longer get micro bubbles in the tube.
The 18mm is distance below the laser air nozzle and the item that is being cut.
I re-measured it, and the plastic tool that came with the machine is 19.8 mm wide.
Attachment 302606
Attachment 302608
From what I've read, the normal distance for this is around 6mm, but I have done some tests and the distance between my nozzle and the item to be cut definitely needs to be about 20mm
The downside of this, is that I don't think there is enough air pressure from the nozzle to quench the flames when cutting MDF or cork. I'm finding it virtually impossible to cut 3mm cork sheet, because using higher power of slower speed just results in more / wider charring rather than deeper cutting. i.e the cut is closing over with carbonized cork.
I was going to attach my 2HP air compressor but I realized that the regulator had packed up, so I will need to get another one before I can have a go at increasing the air supply.
