586,378 active members*
2,573 visitors online*
Thread: Surfcam 2016
Results 1 to 10 of 10
    Feb 2012
    125
    Surfcam 2016
    Today I click accidentally on F1 key and help appears.
    I was amazed because I saw that the icons were different !!
    Will the 2016 version will have a visual modification?
    Feb 2012
    125
    Re: Surfcam 2016
    Does anyone get 2016 version?
    May 2013
    142
    Re: Surfcam 2016
    It became available the 25th of last month in the Vero Portal.
    Its now called Surfcam Traditional 2016 R1.
    May 2013
    142
    Re: Surfcam 2016
    Found my first glitch.
    Moving geometry from one layer to another causes a complete shutdown of Surfcam without warning.
    Feb 2012
    125
    Re: Surfcam 2016
    Quote Originally Posted by Billetgrip View Post
    Could not reproduce this error. Here works normal.
    One thing I notice is CTRL+V, to activate Cview don't work.
    May 2013
    142
    Re: Surfcam 2016
    Quote Originally Posted by forjaco View Post
    Happens on my work AND home comp. About to load it on the other 3 comps here and see if it happens.
    Try CTRL+C
    Feb 2012
    125
    Re: Surfcam 2016
    I try and at 2nd It closes. I open again and keep trying about 5 times and are OK.
    Try CTRL+C
    CTRL+C are OK, but not CTRL+V
    May 2013
    142
    Re: Surfcam 2016
    Have you found any advantage to using 2016 over 2015 yet?
    So far the only improvement I've found is the "Face Mill" toolpath seems to make more sense when using the spiral method. It doesn't make that useless pass in the middle anymore.
    Feb 2012
    125
    Re: Surfcam 2016
    No. Today I report 5 bug to support.I will continue to use the 2015 until 2016 be corrected.
    May 2007
    71
    Re: Surfcam 2016
    At C:\Users\Public\SURFCAM\SURFCAM2016\Config\
    Open surfcam.ini
    Find UseNewToolbarStyle=1
    Change 1 to be 0
    You will get the 2015 Icons
  1. 8050M - error plc 2016
    By HonyaX in forum Fagor Automation
    Last Post: 03-03-2023, 09:44 AM
  2. Change the language CAMWorks 2016
    By przemolinko in forum CamWorks
    Last Post: 11-25-2015, 01:08 PM
  3. ez-mill pro 2016 new features
    By ezcam-user77 in forum EZ-CAM Solutions
    Last Post: 11-21-2015, 12:03 PM
  4. ZW3D 2016 CAD Preview
    By Seanyaohan in forum Uncategorised CAD Discussion
    Last Post: 11-06-2015, 02:30 AM
  5. Monitor Replacement on Fadal 2016 - Need Help
    By WmGuildenstern in forum Maintenance DIY Discussion
    Last Post: 12-07-2012, 06:33 PM
