I just received the Tormach version of Sprutcam 10. I installed it and tried a simple face mill and then separately a 2d contour operation. However, when I tried to do the normal simulation, it just hourglasses and does nothing until I get the message the program has stopped responding. I turned off the various buttons like gouge detection but got the same thing.
I did appear to post a good code, but I did not run it on the machine. Also, the fast simulation of the operation does show the expected result.
Other observations... The rapid feed was 500 and showed in read in the simulation tab detail. I changed it to 100. There are a few other lines that also show in red.
Does anyone have an idea on what I should check, or a setting to check to get it to work? Has anyone else had this problem?
Thanks for the help.
