586,089 active members*
3,957 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How well do the factory probe routines work for simple work & tool offsets?
    Apr 2008
    10
    I'm considering buying a 2001 Fadal with the MP11 and TS27R Renishaw probes installed. How well do the factory probe software routines work for basic tool and work offsets? It sounds like the later machines had all the basic setup routines in the control with no need for additional software from Renishaw. Is this true?
    I tend to do low volume (<200 pcs a run) and prototype work. I think having the probes would make set-ups easier and reduce operator error
    Any response is appreciated.
    May 2005
    53
    Re: How well do the factory probe routines work for simple work & tool offsets?
    We have the TS27R probe for tool touch off and it works fine even in our not so friendly to the machine enviorment (a college). I use a "home made" macro to pick up the tools as the cycle that came with the machine didn't work so well(a long story). If you decide to buy the machine let me know and I would be happy to share the program with you.
    jp
    Apr 2008
    10
    Hi JP,
    Thanks for responding. I'd like to take a look at the probe macros you wrote...I might learn something
    My email is: [email protected].
    Jim
  1. Using the passive touch probe/ setup/ work offsets
    By Stevos758 in forum Tormach PathPilot™
    Last Post: 03-26-2015, 03:19 AM
  2. Help understanding work offsets and extended work offsets
    By tomvoutsas in forum Tormach Personal CNC Mill
    Last Post: 09-20-2013, 06:35 AM
  3. Probe sets work offsets
    By endmill in forum G-Code Programing
    Last Post: 01-17-2009, 06:28 PM
  4. Help With Work Offsets and Touch Off Probe
    By metx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2008, 04:31 PM
  5. Best way to set work/tool offsets?
    By TechCenterTeach in forum Haas Mills
    Last Post: 12-29-2007, 06:27 PM
