Okay. I hooked up the electronics and heater. Man, that heats up fast. Before I could get the controller set correctly, the heater blew out. I knew I should have disconnected it first.
I considered the heater part to be consumable anyway. I have a few more on the way, but USA made ones too. A couple Chinese and a couple USA made should keep me going. I don't think the heater should have burned out, so it probably had a factory issue anyway. It was only up around 300 C, which is hotter than I will typically be using, but within operating range on the heater.
The controller works great though. I was thinking that I might need two heat bands on this? No way. Now my pipe is 5" long. I have ordered a 3.5" instead. I think that will be a more suitable length.
I also ordered the next size up for the ram. I will go ahead and bore out the new SS pipe nipple anyway. I am sure that will help eliminate some messy situations I could have had with standard pipe nipples.
Since I already had the press, this is turning out to me one of the simpler things that I have made or tried to make. I still have a couple more projects that are in limbo for one reason or another, but still on the to do list.
