586,546 active members*
3,319 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > SprutCAM v9 & v10 Compatibility?
    Nov 2015
    I've read through the SprutCAM v10 documentation and haven't been able to find any details on this.
    Will SprutCAM v10 open v9 project files?
    If not, can SprutCAM v9 and v10 be installed on the same machine?
    Thanks!
    Nov 2007
    2151
    Re: SprutCAM v9 & v10 Compatibility?
    I don't have a problem with any conversions. I do save new v10 versions in a new directory. Only problem I see now and then is some 2d operations get confused but easy to fix. And maybe a custom tool / definition that was working before is goofy now or creates some goofy tool paths. Some of my undercut type tools needed some changes to work right. Many of these have been added new in this version and work much better now anyway. I had another problem with collision detection but it turned to be me! So many settings and one wrong your chasing tail for few minutes. Always takes a little doing to upgrade I guess.
    Oh and they give me 90 days to return the key so you could run both for couple months.
  1. Transition from no Sprutcam to Sprutcam-9
    By Uman in forum SprutCAM
    Last Post: 06-09-2015, 12:58 PM
  2. Sprutcam 7 compatibility
    By popspipes in forum Tormach PathPilot™
    Last Post: 04-13-2015, 03:34 AM
  3. 64 bit compatibility?
    By Teyber12 in forum Uncategorised CAD Discussion
    Last Post: 06-29-2010, 12:07 AM
  4. Cat 40 compatibility with BT 40
    By inertialabs in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2007, 12:53 AM
  5. Compatibility
    By elogicca in forum Open Source Controller Boards
    Last Post: 06-09-2006, 10:34 PM
