586,032 active members*
2,805 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Microkinetics-CNC-mill-with Drive Rack and Control Panel
    Sep 2011
    474
    Attached Thumbnails Attached Thumbnails 20151020_134351.jpg   20151020_134559.jpg
    15362
    Re: Microkinetics-CNC-mill-with Drive Rack and Control Panel
    Quote Originally Posted by SwampDonkey View Post
    The mill comes with everything including the drive rack and MN400 motion controller. The Z axis is a custom precision unit that uses linear rails and a ballscrew instead of the crank and wormscrew the kit came with. Comes with extra driver and plug for 4th axis. We will probably use U-Ship since they have the most reasonable rates for large items like this. I'll try to save you as much money on shipping as I can. Freight with this company an vary from $400-$650.$2500 for the whole thing.
    There's nothing Precision about having a round linear rail for the Z axes, that would be junk on a mill, like this, it's also a round column, does not compare to the square column mills that are everywhere now
    Mactec54
    Jan 2009
    234
    Only thing worth a salt in that package is the Drive's and Power Supplies. If you did buy it there is no support as it runs proprietary software that cannot be configured at all and if you need support they want $1,500 or so to register the machine to you as a new owner before they will even sell you a darn cable.
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  1. Simi-Build: Microkinetics MN400 Controller Replacement Just Using The Drive Rack!
    By Contract_Pilot in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2014, 10:16 AM
  2. Need a Manual For Microkinetics Drive Rack Model # 3400-304
    By Contract_Pilot in forum CNC Machine Related Electronics
    Last Post: 09-30-2014, 02:44 AM
  3. Replies: 0
    Last Post: 12-18-2013, 03:43 AM
  4. Why you don't want a Microkinetics control system for plasma!
    By panozeng in forum Waterjet General Topics
    Last Post: 04-13-2010, 04:24 AM
  5. My X2 Mill/Enclosure/Bench/Control Panel, CAD Rendring!
    By QSPSB in forum Benchtop Machines
    Last Post: 12-30-2009, 12:00 AM
