586,065 active members*
4,327 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 63
  1. #21
    Oct 2004
    298
    Re: The 440 has arrived!
    Thanks! I have a lot of 'instructional' videos planned (sprinkled in with projects I'm doing), and they're the videos I would want to see if I was thinking about buying the mill, so yeah, I get what they're doing. It's great for the community.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
  2. #22
    Oct 2004
    298
    NOTE!
    I made a mistake, the feet are in fact M12-1.75. They are just so close to 1/2-13 that I got them confused. 1/2-13 MIGHT work, but M12-1.75 is the right size, sorry about that!
  3. #23
    Quote Originally Posted by cowanrg View Post
    However, I've done a lot of videos through the electronics company SparkFun Electronics.
    HA! I read this, looked to the left and saw your avatar, and immediately recognized THE BEARD! After having watched your Sparkfun New Product videos for years, it's good to see you back on YouTube Rob.
    Funny seeing you here on CNCZone, but it's always good seeing someone else who likes to play on both the mechanical and electrical side of things!
    Dave
  4. #24
    Oct 2004
    298
    Quote Originally Posted by dammachines View Post
    Dave
    Thanks! Interesting fact... I was a member on CNC Zone years before I ever worked for SparkFun. CNC is my original passion.
  5. #25
    Oct 2004
    298
    Hello again everyone. I have another video done today. This one shows some of the final setup and also a look inside the control cabinet.
  6. #26
    Jul 2004
    1424
    It is interesting that Tormach has gone with a 3 axis stepper motor controller instead of having separate drivers for each axis. Advantage: saves space. Disadvantage? If you ever burn up a driver, it is going to cost more to replace.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  7. #27
    Oct 2004
    298
    Yeah, I was a little surprised by that too. But then again, it is an economical option. Notice there's not a breakout board in there... That's gotta save a lot of cost. I'm really curious how the 4th axis and other accessories will work. I plan on getting the 4th axis once it comes out, so I'll find out soon enough.
  8. #28
    Apr 2015
    93
    No need to speculate on actual facts.The leadshine website states, "The MX3660 adopts modular designs. If any of the three stepper drive modules malfunctions, a user can simply replace it with a Leadshine SDM660 stepper drive module at minimal cost." Now for the speculation, Tormach will likely just add another SDM660 drive for 4th axis.
  9. #29
    Jun 2004
    6618
    Those are nice drives.
    I have the MX4660 on my plasma cutter and it does a great job.
    Lee
  10. #30
    Oct 2004
    298
    Gilmax, good find. Looks like you'd have to completely open up the MX3660 and swap out the board. Not a big deal, but obviously more work than if they used 3 separate driver boards. However, I doubt you'd be able to add an SDM660, seeing as the MX3660 doesn't have the room or cutouts for an extra board. Here's a better idea of what they will probably do:
  11. #31
    Jul 2004
    1424
    wow, missed that.
    Interesting to see Tormach going with the "generic" solution instead of their personally designed/procured BOB. Definitely cuts down on wiring.
    The modular design is cool; I didn't realize that it contained user-replaceable components.
    Quick google shows a picture of the modules inside the MX3660:
    Picture sourced from Andrew's superior G0704 build thread:
    http://www.cnczone.com/forums/bencht...6-forum-5.html
    Tim
  12. #32
    Oct 2004
    298
    Yeah, I was curious about that too (the MX4660). The price difference is about $60. I'm sure they figured out how many customers end up buying a 4th axis kit. I bet only 10% of people end up getting a 4th axis, so adding an extra $60 cost to cover the 10% wasn't worth it? The suggested driver is about $100 retail (DM556) and is probably very similar to what they already use in the 4th axis kits. Since they already carry a single-axis motor driver, might as well just use that for the upgrade.
  13. #33
    Jun 2004
    6618
    I would think they have a plan for it.
    It's still pretty new, so all the info isn't out yet. They may have the MX4660 as an option later on.
    Lee
  14. #34
    Oct 2004
    298
    Hey guys, I'm back with another video!
    I decided to do some mods that will only make using the machine better for future videos. Also, dubstep. Check it out:
  15. #35
    Jun 2004
    6618
    Great video as always. Lighting is a necessity for sure.
    Nice mods as well.
    I do have a question though.
    Why doesn't the controller shut down by itself?
    I haven't opened my controller cabinet since I installed the front panel mount USB port.
    I need to do this to check that the dust content though just as maintenance.
    When I shut down, I get a screen on PP that says it's safe to turn off the machine power now.
    Does yours not do this?
    Likewise when I crank up, I just turn the power on and the computer boots too.
    Lee
  16. #36
    Oct 2004
    298
    I get the screen that says it's safe to shut off, but the computer isn't connected to the controller, other than the DB25. Is the computer's power supply plugged into the controller? If so, that's what's happening. When you turn on your controller, it turns on the computer, and when you turn off the controller, it cuts power to pathpilot.
  17. #37
    Jun 2004
    6618
    Right.
    The lathe has several receptacles in back that are labelled. One is for the computer/controller. Is that not how the 440 works?
    Lee
  18. #38
    Oct 2004
    298
    I'll check when I get home. There is one plug coming out the back, but I assumed that was for the flood coolant. I'll check, but I think that's the only one.
  19. #39
    Jun 2004
    6618
    I didn't think the 440 was setup for flood coolant. Maybe a mister? Of course, you are in a better position to know that than I am.
    Lee
  20. #40
    Oct 2004
    298
    The 440 does have an optional flood coolant kit, check the product page for the deluxe kit:
    35684 - PCNC 440 Deluxe Package w/Stand
    I haven't received it yet because it was backordered. But it should show up soonish.
Page 2 of 4 1234
  1. Sieg x2 arrived
    By rollerlocked in forum Benchtop Machines
    Last Post: 08-28-2014, 03:11 AM
  2. New Romaxx Just Arrived!!!!
    By aussiegazza in forum Wood Lathes / Mills
    Last Post: 06-11-2011, 04:18 AM
  3. New Syli X6 Arrived, need help
    By shenta in forum Syil Products
    Last Post: 06-08-2011, 01:24 PM
  4. My Romaxx HS-1 Arrived
    By mattgatten in forum Commercial CNC Wood Routers
    Last Post: 02-12-2009, 03:37 PM
  5. It has arrived :)
    By ullbergm in forum DIY CNC Router Table Machines
    Last Post: 03-09-2004, 04:03 PM
