4 axis ATC cnc wood router STM1325-4
4 axis ATC cnc wood router STM1325-4 include a 9kw HSD high frequency automatic tool changer spindle with an 8 Position rotary carousel tool holder, the spindle(C axis) can rotate +/- 90 degree, for side slot milling, drilling, cutting, keyhole, very suitable for processing of on different surface carving.
Advantage
1. Big steel tube welded structure, after aging and tempering treatment, reliable and stable and not easy to deformation.
2. Top-quality components, HSD 4 axis ATC spindle, Delta inverter, TBI ball screw, Yaskawa servo motors, Syntec control system and so on.Long-time working time, high precision and efficiency.
3. Carrousel Tool Magazine system with 8 forks and 4 tool holders , which is loaded with the spindle , make the machine change tools quickly and save time.
4. Many optional configuration and OEM service available. According to your requirement, different configurations will be offered.
Features
1. HSD spindle ----original famous brand from Italian,also can choose Hitech spindle
2. SYNTEC control system------It is from Taiwan with high performance and competitive price
3. Yaskawa servo motor and drives----They are from Japan with high precision and long life
4. HIWIN linear guide ------ made from Taiwan,used for linear reciprocating stadium
5. Working area:1300*2500*400mm,C Rotary Axis:360 degree
6. Whole cast steel structure thicken to 10mm
7. Drive System: X,Y-Rack Z-Ball Screw,Z with high precision ball screw
8. Automatic Tool Calibration -----To guide rail and slide block , make it run better
9. Schneider electrical components -----original brand from France
10. Japanese Omron Switch with long life
11. APEX Reudcer from Taiwan----More powerful and higher precision
12. T-Slot table with Aluminum sheel ------Use clamp fixed materials
Jinan Style Machinery is a professional manufacturer and supplier from China for sale a series of CNC products such as CNC router machine,Laser cutting machine,Laser marking machine,Laser engraving machine,Panel furniture production line and Plasma cutter width over 10 years of experience.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
