Can someone explain how to set-up the Soft Limits?
The axis numerical settings are listed in the axis settings page with two entries of the + limit and - limit. The manual states to simply check the Soft Limits box to implement the Soft Limits. There are numbers displayed on the diagnostic page for each axis, and they change as the machine is jogged. The numbers displayed are whole numbers, no decimal point, and with a minus sign. This is after homing the machine.
After checking the Soft Limits box, the Z axis will not jog in the + direction, on negative (down). Unchecking the box, restores the Z moving both directions.
The manual is not very descriptive at all.
When homing the machine, the machine setting is 0, for the Z axis, but the Z axis number on the diagnostic page is some numerical value, like -307.
Much needs to be done in the "User Manual" department.
Testing out the Soft Limits results in many, many crashes, with nothing gained.
Any help apprediated.
John M.
