Can't get Cooling fan to run.
I have a Huanyang Model:HY-7.5KW 220 3phase. I'm running it on single phase 220. I've got it running successfully using the built in key controller. the cooling fan is not running. the inverter will run for 10/15 minutes then overheats and shuts down. anybody know the parameter number that controls the fan. my understanding is that it should start 5 seconds after the inverter starts the load motor ?
thanks
