Is there such a thing as an angular contact ball bearing with a 0.25" inside diameter, with a flange or snap ring groove? OD doesn't matter, but I want the flange or groove on the thrust side of the bearing.
I want to mount a 5/16" diameter ball screw under slight tension and such a bearing would make the mounts very simple, just bore holes, assemble screw and bearings then tighten one end and adjust the other with a lock nut. Higher speed running without whip or having the screw try to bend when driving away from the motor.
I already have the screw, with 0.25" ground and threaded end.
